WiFi cloud attachment to portal
Related to the Portal
GermanDude
Post by GermanDude »
Will the new cloud wifi also be able to connect to the portal?
Also the iPhone/iPad app does not connect to my cloud wifi..
-James-
Re: WiFi cloud attachment to portal
It can, but the portal will require you to use ip/port and thus you need to setup port forwarding on your router.
GermanDude
Ok, once I get the attachment module to work with my RA+, I will try that.
-James-
GermanDude
It works on the portal. Woohoo.....
-James-
