ato time out
Posted: Mon Nov 10, 2014 6:04 pm
by Ademster
is there a way to eliminate the time out for the ato?
the way I have my ato system set up it would be impossible for it to flood the sump.
and trying to remember to check the flags is a pain.
thanks in advance
Adam
Re: ato time out
Posted: Tue Nov 11, 2014 8:17 am
Just set it high enough that it would never get triggered...and if it did it might just save your tank
but regardless the only way would be to not use the ATO function and just turn on/off the relay based on your criteria (float switch status/water level/etc)
Re: ato time out
Posted: Tue Nov 11, 2014 1:09 pm
by Ademster
I have set at the max of 255.
How would I code port 4 to turn on when water level reaches 95 and turn off when water level reaches 100?
Re: ato time out
Posted: Tue Nov 11, 2014 1:18 pm
if (ReefAngel.WaterLevel.GetLevel()<95) ReefAngel.Relay.On(Port1);
If (ReefAngel.WaterLevel.GetLevel()>=100)
ReefAngel.Relay.Off(Port1);
Re: ato time out
Posted: Tue Nov 11, 2014 7:30 pm
by Ademster
Thanks Lnevo.
I discovered my problem. I thought I put 255. but only put 25 I didn't double tap good enough hahaha
all is working fine, I had it timed to fill and it should only take X time, was wondering why it was timing out before finishing.
