Circles, min/max pde
Posted: Wed Jan 18, 2012 9:00 pm
by jsclownfish
I made this menu screen because I liked the view of the outlets to look like the outlet box (so I could label them and remember which was which) and I thought circles would be more appealing. This pde also has the min/max functions to show when the temp and pH peaks. Turns out it's kind of a memory hog, but I thought folks might want to use the circles if they have the space. Can you add the function to the LCD library?
(the temp probes for the room and sump weren't hooked up when I took the picture)
Jon
Here's the pde...
#include <ReefAngel_Wifi.h>
#include <ReefAngel_EEPROM.h>
#include <ReefAngel_ATO.h>
#include <ReefAngel_LED.h>
#include <ReefAngel_Relay.h>
#include <ReefAngel_PWM.h>
#include <ReefAngel_Timer.h>
#include <ReefAngel_Memory.h>
#include <ReefAngel_Colors.h>
//Actinic and Daylight PMW are on the LED moonlights
byte ActinicPWMValue=0;
byte DaylightPWMValue=0;
int maxTemp=0;
int minTemp=2000;
int maxPH=0;
int minPH=1000;
time_t tsmax=now();
time_t tsmin=now();
time_t PHmax=now();
time_t PHmin=now();
byte wmport=Port5;
boolean wmdelay=false;
byte wmpulse=0;
#include <avr/pgmspace.h>
// Labels for the web banner
prog_char id_label[] PROGMEM = "jsclownfish";
prog_char probe1_label[] PROGMEM = "Tank";
prog_char probe2_label[] PROGMEM = "Room";
prog_char probe3_label[] PROGMEM = "Sump";
prog_char relay1_label[] PROGMEM = "Heater1";
prog_char relay2_label[] PROGMEM = "Heater2";
prog_char relay3_label[] PROGMEM = "MHalide";
prog_char relay4_label[] PROGMEM = "Actinic";
prog_char relay5_label[] PROGMEM = "WM1";
prog_char relay6_label[] PROGMEM = "WM2";
prog_char relay7_label[] PROGMEM = "Main";
prog_char relay8_label[] PROGMEM = "Fan";
void DrawTime(byte x, byte y, byte FGcolor, byte BGcolor, time_t ts)
//byte iTimeHourOffset=0;
    char text[13];
    char temp[]="  ";
    strcpy(text,"");
    //if (iTimeHour>12) iTimeHourOffset=12;
    itoa(hourFormat12(ts),temp,10);
    if (temp[1]==0) strcat(text,"0");
    strcat(text,temp);
    strcat(text,":");
    itoa(minute(ts),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(second(ts),temp,10);
    strcat(text,temp);
    if (isAM(ts))
        strcat(text," AM");
        strcat(text," PM");
    ReefAngel.LCD.DrawText(FGcolor, BGcolor, x, y, text);
void DrawCircle(int a, int b, int r, byte color)
//void ReefAngel_NokiaLCD::PutPixel(byte color, byte x, byte y)
  int f = 1 - r;
  int ddF_x = 1;
  int ddF_y = -2 * r;
  int x = 0;
  int y = r;
 ReefAngel.LCD.PutPixel(color, a, b+r);
 ReefAngel.LCD.PutPixel(color ,a, b-r);
 ReefAngel.LCD.PutPixel(color, a+r, b);
 ReefAngel.LCD.PutPixel(color, a-r, b);
 while (x<y)
 if (f >= 0)
 {      y--;
       ddF_y += 2;
       f += ddF_y;
   x++;
   ddF_x += 2;
   f += ddF_x;
   ReefAngel.LCD.PutPixel(color, a + x, b + y);
   ReefAngel.LCD.PutPixel(color, a - x, b + y);
   ReefAngel.LCD.PutPixel(color, a + x, b - y);
   ReefAngel.LCD.PutPixel(color, a - x, b - y);
   ReefAngel.LCD.PutPixel(color, a + y, b + x);
   ReefAngel.LCD.PutPixel(color, a - y, b + x);
   ReefAngel.LCD.PutPixel(color, a + y, b - x);
   ReefAngel.LCD.PutPixel(color, a - y, b - x);
void FillCircle(int a, int b, int r, byte color)
   int f = 1 - r;
   int ddF_x = 1;
   int ddF_y = -2 * r;
   int x = 0;
   int y = r;
for (int i=b-r; i<=b+r; i++)
  ReefAngel.LCD.PutPixel(color, a, i);
while (x<y)
if (f >= 0)
   y--;
   ddF_y += 2;
   f += ddF_y;
   x++;
   ddF_x += 2;
   f += ddF_x;
   for (int i=b-y; i<=b+y; i++)
ReefAngel.LCD.PutPixel(color, a+x, i);
ReefAngel.LCD.PutPixel(color, a-x, i);
for (int i=b-x; i<=b+x; i++)
ReefAngel.LCD.PutPixel(color,a+y, i);
ReefAngel.LCD.PutPixel(color,a-y, i);
//circle matched outletbox
void DrawCircleBox (byte x, byte y, byte RelayData)
 byte b = 0;
 byte c = 0;
 byte d = 0;
    for (byte a=0;a<2;a++)
        DrawCircle ((a*10)+x,y,5,COLOR_BLACK);
        if ((RelayData&(1<<a))==1<<a)
          FillCircle((a*10)+x,y,3,OutletOnBGColor);
          FillCircle((a*10)+x,y,3,OutletOffBGColor);
   for (byte a=2;a<4;a++)
        b=(a-2)*10;
       DrawCircle (b+x,y+10,5,COLOR_BLACK);
          FillCircle(b+x,y+10,3,OutletOnBGColor);
          FillCircle(b+x,y+10,3,OutletOffBGColor);
    for (byte a=4;a<6;a++)
        c=(a-4)*10;
       DrawCircle (c+x,y+20,5,COLOR_BLACK);
          FillCircle(c+x,y+20,3,OutletOnBGColor);
          FillCircle(c+x,y+20,3,OutletOffBGColor);
    for (byte a=6;a<8;a++)
        d=(a-6)*10;
       DrawCircle (d+x,y+30,5,COLOR_BLACK);
          FillCircle(d+x,y+30,3,OutletOnBGColor);
          FillCircle(d+x,y+30,3,OutletOffBGColor);
// update the min and max temps
if (now()%86400==0)
  minTemp=ReefAngel.Params.Temp1;
  maxTemp=ReefAngel.Params.Temp1;
if (ReefAngel.Params.Temp1<minTemp)
  tsmin=now();
//  DrawTime(60,33);
if (ReefAngel.Params.Temp1>maxTemp)
  tsmax=now();
//  DrawTime(60,23);
DrawTime(60,23,0, COLOR_WHITE,tsmax);
DrawTime(60,33,0,COLOR_WHITE, tsmin);
if (now()%86400==0)
  minPH=ReefAngel.Params.PH;
  maxPH=ReefAngel.Params.PH;
if (ReefAngel.Params.PH<minPH)
  PHmin=now();
//  DrawTime(60,33);
if (ReefAngel.Params.PH>maxPH)
  PHmax=now();
//  DrawTime(60,23);
DrawTime(60,55,0, COLOR_WHITE,PHmax);
DrawTime(60,65,0,COLOR_WHITE, PHmin);
// Display the Tank temperature with color sensors
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,13,"TANK:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp1, COLOR_BLACK, 36, 13, 10);
// Display the Room temperature
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor, 70 ,120,"R00M:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp2, COLOR_BLACK, 100, 120, 10);
ReefAngel.LCD.DrawText(T3TempColor,DefaultBGColor,63,13,"SUMP:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.Temp3, COLOR_BLACK, 91, 13, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,23,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxTemp, 0, 23, 23, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,23,"at");
// Display the Sump temperature
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,5,33,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minTemp, 0, 23, 33, 10);
ReefAngel.LCD.DrawText(T1TempColor,DefaultBGColor,48,33,"at");
//Display the pH
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 44,"PH:");
ReefAngel.LCD.DrawSingleMonitor(ReefAngel.Params.PH, 0, 23, 44, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor,5, 54,"HI:");
ReefAngel.LCD.DrawSingleMonitor(maxPH, 0, 23, 54, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 48, 54,"at");
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 5, 64,"LO:");
ReefAngel.LCD.DrawSingleMonitor(minPH, 0, 23, 64, 100);
ReefAngel.LCD.DrawText(PHColor,DefaultBGColor, 48, 64,"at");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,10,78,"Heat1");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,10,88,"MH LT");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,10,98,"WM LT");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,10,108,"MainP");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,80,78,"Heat2");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,80,88,"ActLT");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,80,98,"WM RT");
ReefAngel.LCD.DrawText(T2TempColor,DefaultBGColor,80,108,"Fan");
DrawCircleBox (55,80,TempRelay);
// ReefAngel.LCD.DrawOutletBox(12, 100, TempRelay);
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(0, 1, 11, 132, 11);
  ReefAngel.Init();  //Initialize controller and start web banner timer
  ReefAngel.Timer[4].SetInterval(180);  // set interval to 180 seconds
  ReefAngel.Timer[4].Start();
  ReefAngel.FeedingModePorts = B00110000;
  ReefAngel.WaterChangePorts = B10110000;
//  ReefAngel.OverheatShutoffPorts = B00000111;
//  ReefAngel.LightsOnPorts = B00001100;
  ReefAngel.Relay.On(Port5);
  ReefAngel.Timer[1].SetInterval(InternalMemory.WM1Timer_read());
  ReefAngel.Timer[1].Start();
  ReefAngel.Relay.On(Port7);
  // Specific functions
  //1st Heater at 78.8, 2nd Heater at 77.0, MH on at 10AM off at 8PM, Actinics on at 9AM off at 9PM, Fan kicks on at 82.0
  ReefAngel.StandardHeater(Port1,788,792);
  ReefAngel.StandardHeater(Port2,770,792);
  ReefAngel.MHLights(Port3,10,0,20,0,5);
  ReefAngel.StandardLights(Port4,9,0,21,0);
  ReefAngel.StandardFan(Port8,792,820);
  // Wavemaker Code with night option
  if (ReefAngel.Timer[1].IsTriggered() )
    if ((hour() >= 21) || (hour() <= 8)) //from 9p-Midnight
    {  //PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM,
       // byte endPWM, byte Duration, byte oldValue)
      wmpulse=PWMSlope(21,0,8,0,5,30,179,30);
      if (wmdelay)
        ReefAngel.Timer[1].SetInterval(wmpulse);  // WM delay function from 30-170 sec.
        ReefAngel.Relay.Off(Port5);
        ReefAngel.Relay.Off(Port6);
        if (wmport==Port5) wmport=Port6; else wmport=Port5;
        wmdelay=false;
        ReefAngel.Timer[1].SetInterval(200-wmpulse);  // WM bursts timing from 170-30 sec.
        ReefAngel.Relay.On(wmport);
        wmdelay=true;
      //8a-10p normal wave settings
  //Using Daylight ATO high signal piezo buzzer when temp exceeds 83F
  //other options are lowATOpin or the LED pins as ReefAngel.PWM.SetDaylight(100); else ReefAngel.PWM.SetDaylight(0);
if (ReefAngel.Params.Temp1>830)
  pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,HIGH);
  {pinMode(highATOPin,OUTPUT);
  digitalWrite(highATOPin,LOW);
    //Moonlight=byte PWMSlope(byte startHour, byte startMinute, byte endHour, byte endMinute, byte startPWM, byte endPWM, byte Duration, byte oldValue)
   ActinicPWMValue=PWMSlope(7,00,22,0,0,100,60,ActinicPWMValue);
   DaylightPWMValue=PWMSlope(7,00,22,0,0,100,60,DaylightPWMValue);
// Web Banner stuff
        ReefAngel.WebBanner();
Re: Circles, min/max pde
Posted: Wed Jan 18, 2012 9:06 pm
That's so cool!! :)
I'm sure we can add circles to the libraries.
Posted: Fri Feb 10, 2012 10:05 pm
by psyrob
Hey, this is great and I am trying to mod your code to fit my outlet box and I am stumped...The way I have my outlet box mounted, the outlets are all the reverse of yours....where in the code would I switch to have all the left hand side outlets be on the right and vice versa? I can figure out how to switch the text, but I can't figure out how to switch the circles...
Posted: Sat Feb 11, 2012 6:54 am
by binder
It's in this function:
byte b = 0;
byte c = 0;
byte d = 0;
        b=(a-2)*10;
        c=(a-4)*10;
        d=(a-6)*10;
He draws each row at a time. Draws top row (ports 1 & 2), then 3 & 4, and so forth.
So it sounds like you are wanting to have the ports display like this:
2 1
4 3
6 5
8 7
Instead of:
1 2
3 4
5 6
7 8
Is that correct?
Posted: Sat Feb 11, 2012 8:13 am
by jsclownfish
Curt will know better, but I think you just need to change the a++ to a-- so it counts down instead of up at each line of the relay box. You'll also need to add the draw and fill circle functions the draw circle box calls.
-Jon
Posted: Sat Feb 11, 2012 10:16 am
by psyrob
Curt, your right about how I want to have the outlets line up...thanks guys, I will try it later
Posted: Sat Feb 11, 2012 10:21 am
by binder
I'm gonna work up an example code change for you later today when I get home.
Posted: Sun Feb 12, 2012 12:08 pm
by psyrob
Jon,
I tried changing the ++ to -- , but the the code won't upload...it started to the process, then froze...didn't get an error message. I will tinker some more, and in the meantime, I will hold a mirror up to the screen to make the ports be in reverse! LOL
Posted: Sun Feb 12, 2012 4:33 pm
by jsclownfish
After I thought about it a bit, that was too simple. I'll try to change the code a bit to see if I can switch it over. I think I was using the outlet number to direct position and relay status on the display. I'll think on it a bit if Curt doesn't already have a solution.
-Jon
Posted: Sun Feb 12, 2012 4:42 pm
by binder
I haven't coded a solution yet. I thought I was going to get to it yesterday but didn't. It's not just as simple as using -- instead of ++. You still have to keep the same order of logic for displaying them because of the spacing and alignment. The main thing you have to focus on is flipping the bitwise comparison.
Here's a quick flipping of things. It "should" work but I have not tested it out. I trimmed down the number of variables used and cleaned up a couple things.
byte a = 0;
byte b = 0;
byte c = 0;
    for (a=0,c=1;a<2;a++,c--)
// 0 & 1
        if ((RelayData&(1<<c))==1<<c)
   for (a=2,c=3;a<4;a++,c--)
// 2 & 3
        b=(a-2)*10;
    for (a=4,c=5;a<6;a++,c--)
// 4 & 5
        b=(a-4)*10;
       DrawCircle (b+x,y+20,5,COLOR_BLACK);
          FillCircle(b+x,y+20,3,OutletOnBGColor);
          FillCircle(b+x,y+20,3,OutletOffBGColor);
    for (a=6,c=7;a<8;a++,c--)
// 6 & 7
        b=(a-6)*10;
       DrawCircle (b+x,y+30,5,COLOR_BLACK);
          FillCircle(b+x,y+30,3,OutletOnBGColor);
          FillCircle(b+x,y+30,3,OutletOffBGColor);
You are still drawing things in the same order but the only difference is you are checking the status of the last port first and updating the first circle with that, then proceeding onward.
Posted: Sun Feb 12, 2012 6:00 pm
by psyrob
Curt:
I uploaded and this works like a charm...thanks for you help...screen shot below
Don't know why, but my relay box is lined up opposite the way other people's seem to be...relay 1 is on the top right corner and relay 2 is on the top left, if you have the data cable port pointing down...
Posted: Sun Feb 12, 2012 6:12 pm
by binder
Nice. Glad it works for you.
screenshot looks great! :)
Posted: Wed Mar 21, 2012 8:46 pm
by binder
I just finished adding this into the libraries. I made some tweaks to it for better and improved functionality. I merged the reverse displaying into one function and made it adhere to the standard color scheme / coordination. I also renamed some of the functions to add more clarity to them. This will be in the 0.9.4 release.
Here are the functions added to the LCD library (RA_NokiaLCD):
void DrawCircleOutline(byte x, byte y, byte radius, byte bordercolor);
void FillCircle(byte x, byte y, byte radius, byte fillcolor);
void DrawCircleOutletBox(byte x, byte y, byte RelayData, bool reverse = false);
To use, you would simply do exactly like you would for the standard outlet box:
This will display the outlet in "normal" fashion
// Normal display like this:
// Outlets in 2 columns
// 1 2
// 3 4
// 5 6
// 7 8
ReefAngel.LCD.DrawCircleOutletBox(10,10,TempRelay);
And reversed:
// Reversed display
// 2 1
// 4 3
// 6 5
// 8 7
ReefAngel.LCD.DrawCircleOutletBox(10,10,TempRelay,true);
There are no numbering on the circles. If you want the labels, you gotta add them in yourself and use code like on the initial post.
Regardless, I just wanted to share that this will be an option for the next release of the libraries. :ugeek:
Posted: Wed Mar 21, 2012 9:25 pm
by psyrob
very cool!!
Posted: Thu Mar 22, 2012 4:32 pm
by jsclownfish
Thanks Curt! It will be nice to have these available for custom screens.
-Jon
Posted: Wed Oct 08, 2014 1:27 pm
by phat
hi i would love to able to use this custom screen but i am not sure as how to do this i don't understand what i should put where in the libraries, i am new to this
i have read this http://curtbinder.info/ragen/docs/RA_Custom_Menu.pdf and added
#define CUSTOM_MENU
to the features file
and this to the RA_NOKIALCD
what else do i need to do ?
Posted: Sat Oct 11, 2014 9:03 am
by phat
anyone ???
Posted: Sat Oct 11, 2014 9:24 am
You shouldn't need to do any of that anymore afaik. I believe you just need to define the functions in your INO DrawCustomMain and DrawCustomGraph and start drawing your screens. I'd say look at my code but it's not a good beginner reference. Take a look at some people's posted INO files for some examples.
