Jebao WP-25
Jadco59
Jebao WP-25
Post by Jadco59 »
I was told that Reef Angel sold a kit to be able to use my Jebao WP-25 pump with my Apex Controller. If this is so can you tell me what I need and will it work properly ?
Re: Jebao WP-25
Yes, you can buy the cable in the ReefAngel store.
Re: Jebao WP-25
It's not a kit.
The cable comes pre-wired for a connection to the header pins on the Reef Angel, you would have to replace that with and RJ-45 connector for your Apex.
There are plenty of guides on the different forums that tell you exactly which wire in the RJ-45 connector need to get connected to the cable.
