Scale or Pressure
skehole
Re: Scale or Pressure
Post by skehole »
I believe it simply implies that it is designed to be running 24/7.
If you ask BRS, for example, if their dosing pumps are designed to be operating 24/7, they will tell you absolutely not. As will most dosing pump manufacturers. For a calcium reactor, water should be pumped in and out at a constant metered pace to keep things consistent. It's very tough to find a pump that is capable of operating constantly, and is capable of overcoming the occasional pressure of clogged effluent lines, etc. it's for this reason why masterflex pumps have such a strong following among calrx users. There are others in the game, kamoer makes a calrx peri pump now, and of course there's the Dastaco calcium reactors thatre at a whole other level.
Paul_Velasco
Post by Paul_Velasco »
rimai wrote:What is continuous duty and why are they different?
If it is continuous, I would imagine it is not controllable or it would be called variable duty, no?
The masterflex pumps just change speed to control flow rate.
