Can't get into portal
Related to the Portal
GugsJr
Post by GugsJr »
I added a webcam stream to my portal now it won't load and I can't get in to change the settings
Re: Can't get into portal
It should eventually fail to connect to the camera and show the portal, no?
Make sure to enter a url string that works before you enter into the settings.
GugsJr
Post by GugsJr »
If I enter it in to a blank tab it works. Here is the website: http://10.0.0.233:59950/videostream.cgi ... l&pwd=fish
This is the only part that shows in the portal. Other then that I get a loading symbol on my tab.
Reef Angel
Reef Angel wifi address: 71.201.255.49:2000
My reefangelid:
GugsJr
Connection Status:
Ready
Last Update:
3/13/2017, 9:32:39 AM
Displaying data from:
Reef Angel Controller (live)
That ip address looks like an internal ip address. It can only be seen from inside your network.
GugsJr
Post by GugsJr »
Thank you. I replaced it with.
http://71.201.255.49:59950/videostream. ... l&pwd=fish
seems to be working
Ok. I removed it.
GugsJr
Post by GugsJr »
Thank you
