Connection failure
Related to the Portal
anderzon_
Connection failure
Post by anderzon_ »
Hi
I have problem with connection to portal.
I have done the installation and port forwarding but still its not working?
rrodriguess
Re: Connection failure
Post by rrodriguess »
Have you updated the wifi attachment?
anderzon_
Post by anderzon_ »
I dont know. Buyed it used. How do i update it? Its the old wifi
rrodriguess
anderzon_
Post by anderzon_ »
ok thanks but i dont understand. What is ssid och passphrase?
anderzon_
Post by anderzon_ »
I have trried to do this in the link but still dont work. Its impossible to connect to the portal. And have done port foreward in my router. One strange thing is that when i put in my ip on the portal setting is that it changes to another number as soon as i log off and log in it has changed again?
Go here:
https://www.yougetsignal.com/tools/open-ports/
Check for port 2000.
Does the ip address shown in that page matches the one in the portal?
anderzon_
Post by anderzon_ »
yes it does. Does it mean that the port is open? What should i do to make the connection work?
When you check port 2000, does it show open?
anderzon_
Post by anderzon_ »
No it says closed for both ip number. But i have the port open Image
