Adding more Temp Probe
Mayur
Post by Mayur »
Hi
Need help with the code for adding 3 more temp probe
ReefAngel.AddExtraTempProbes(); tryed this but there no change in uapp and controller screen only default 3 temp
Re: Adding more Temp Probe
Although they are there for you to use, they are not displayed in any of the apps yet.
You can set a custom var to display them as a work around.
rimai wrote:Although they are there for you to use, they are not displayed in any of the apps yet.
Mine display in the UApp..
I may have changed it then and forgot. :roll:
tkeracer619
Post by tkeracer619 »
rimai wrote:I may have changed it then and forgot. :roll:
I think you did that when I was inquiring about it a couple months ago :lol:
Though, It would be nice if we weren't limited to 6 ;)
I have 11 aquariums, the filtration room, and a gas heating loop I want to monitor. So I need 13 minimum and would like to display them on the UAPP..
Wife is getting me an android tablet for V-day to mount on the wall of the fish room to display the uapp.
I want to use the tablet to display the UAPP, push maintenance reminders, and log test results.
It's all coming together :D
Mayur
Post by Mayur »
Can u share the code
ReefAngel.CustomVar[0]=ReefAngel.Params.Temp[4];
Mayur
Post by Mayur »
For 5 and 6th probe
It will be
ReefAngel.CustomVar[0]=ReefAngel.Params.Temp[5];
ReefAngel.CustomVar[0]=ReefAngel.Params.Temp[6];
Piper
Post by Piper »
Mayur wrote: For 5 and 6th probe
It will be
You would want to use this:
ReefAngel.CustomVar[1]=ReefAngel.Params.Temp[5];
ReefAngel.CustomVar[2]=ReefAngel.Params.Temp[6];
Mayur
Post by Mayur »
still no changes on the controller screen and app
you will have to view the Custom Variables page / screen to see the temp probe values. the code they provided for you puts the temp probe values in the custom variables, they won't show on the main screen.
