Current Hardware Version - Multi Channel Water Lever?
Piper
Post by Piper »
Hey Brennyn,
What is the most recent hardware version for the multi channel water level expansion? I’m having issues with bus locks when I have mine hooked up. The silkscreen on the one I have shows reversion 1.1. I’m trying to troubleshoot and trying to figure out if I possibly have an older version or maybe a bad board.
Charlie
brennyn21
Re: Current Hardware Version - Multi Channel Water Lever?
Post by brennyn21 »
So 1.1 is the last version released by Roberto, I made 1.2 which uses USB C and a newer ADC Chip. Does yours have any corrosion on the connector? Send me a PM and I can just send out a new module so you don't have to buy the whole kit if yours is faulty.
Sincerely, Brennyn
Piper
Post by Piper »
Thanks, Brennyn. No corrosion on the board, connector, or the hub. I’ll shoot you a PM. Thanks!
