Can't save files
all things webwizard here, please share suggestions, issues, or just anything related to the webwizard
kylejordanlibby
Can't save files
Post by kylejordanlibby »
New user here
I want to be able to save/load code within Web Wizard. Whenever I open the menu and click "Save" I get the following error:
Unable to write to file somefilename.ino
Where is this trying to save the file to exactly? I can maintain my own code via git on my own but it would be nice to be able to load it directly in WebWizard
brennyn21
Re: Can't save files
Post by brennyn21 »
Can you try copying the code, clicking new pasting the code and saving it.
I'll have to look into more when I get home, but if my memory serves me correctly if you just uploaded your code it won't let you save it under a different file name as it automatically saves the code as "last uploaded.ino"
Hope this helps I'll do more investigating once I get home.
Sincerely, Brennyn
kylejordanlibby
Tried that and still get the same error. It doesn't matter what I try to save the file name as.
In the browser I can see that the POST request to webwizard/savesketch.php is returning 200 with that message: "Unable to write to file filename.ino"
Maybe related if this is an auth issue... When logging into the Web Wizard I get redirected to the forum ucp.php?mode=login and it displays an error: "The submitted form was invalid. Try submitting again.". When logging in there I am redirected back to the Web Wizard and it looks as if I am authenticated properly.
brennyn21
Post by brennyn21 »
I am looking into the issue and trying to replicate, can you please try it again?
Sincerely, Brennyn
kylejordanlibby
Seems to be working fine now, thanks
