CODE WITH TEMP PROBE PROBLEMS
CASPAR
Post by CASPAR »
THINK I MAY HAVE CREATED THE PERFECT CODE FOR ME, BUT PROBLEM WITH IT IS MY SUMP TEMP ON DISPLAY KEEPS FLUCTUATING FROM SAY 78.5 TO 0.00 ABOUT EVERY MINUTE OR SO??? THEN MY ROOM TEMP PROBE TEMP DISPLAY HAS A GREEN BACKROUND TO IT, AND NOT SUPPOSED TO. THE SUMP FLUCTUATIONS ACCUR REGARDLESS OF WHAT PROBE IS CONNECTED BETWEEN THE 3, HAVE SWITCHED THE PROBES AROUND AND IT STILL DOES IT. ANY HELP APPRECIATED....BELOW IS THE CODE
const char menu1_label[] PROGMEM = "Feeding Mode";
const char menu2_label[] PROGMEM = "Water Change Mode";
const char menu3_label[] PROGMEM = "Cloud On Demand";
const char menu4_label[] PROGMEM = "Clear ATO Timeout";
const char menu5_label[] PROGMEM = "Set Clock";
const char menu6_label[] PROGMEM = "Calibrate pH";
const char *const menu_items[] PROGMEM = {
menu1_label, menu2_label, menu3_label, menu4_label, menu5_label, menu6_label};
byte DaylightPWMValue=0;
boolean ForceCloud=false;
void MenuEntry1()
ReefAngel.FeedingModeStart();
void MenuEntry2()
void MenuEntry3()
ForceCloud=true;
void MenuEntry4()
ReefAngel.ATOClear();
void MenuEntry5()
ReefAngel.SetupDateTime();
void MenuEntry6()
ReefAngel.SetupCalibratePH();
byte x = 6;
byte y = 2;
byte t;
ReefAngel.LCD.DrawDate(6, 2);
ReefAngel.LCD.Clear(COLOR_INDIGO, 1, 11, 132, 11);
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 102, "----------------------");
ReefAngel.LCD.DrawText(COLOR_INDIGO,255, 1, 126, "----------------------");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,56,110, "ATO");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 2, 109, "*");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 2, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255, 45, 111, "H");
ReefAngel.LCD.DrawText(COLOR_RED,255, 45, 121, "I");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 111, "L");
ReefAngel.LCD.DrawText(COLOR_RED,255, 77, 121, "O");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 126, 109, "*");
ReefAngel.LCD.DrawText(COLOR_NAVY,255, 126, 121, "*");
ReefAngel.LCD.DrawText(COLOR_RED,255,14,40,"TANK");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 50, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,99,40,"PH");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 89, 50, text, Num8x16);
ReefAngel.LCD.DrawOutletBox(12, 85, TempRelay);
ReefAngel.LCD.DrawText(COLOR_RED,255,14,63,"SUMP");
ConvertNumToString(text, ReefAngel.Params.Temp[T2_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 10, 72, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,92,63,"ROOM");
ConvertNumToString(text, ReefAngel.Params.Temp[T3_PROBE], 10);
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 92, 89, 72, text, Num8x16);
ReefAngel.LCD.DrawText(COLOR_RED,255,10,110, "White");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 32, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,12,119, ReefAngel.PWM.GetDaylightValue());
//ReefAngel.PWM.GetDaylightValue(),
ReefAngel.LCD.DrawText(COLOR_RED,255,90,110, "Blue");
ReefAngel.LCD.DrawText(COLOR_BLUE,255, 114, 119, "%");
ReefAngel.LCD.DrawText(COLOR_BLACK,255,92,119, ReefAngel.PWM.GetActinicValue());
ReefAngel.LCD.FillCircle(57,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(57,122,3,COLOR_GREEN);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_RED);
ReefAngel.LCD.FillCircle(70,122,3,COLOR_GREEN);
//ReefAngel.PWM.GetActinicValue());
//ReefAngel.LCD.DrawMonitor(15, 60, ReefAngel.Params,
bool atoSpanReached; //flag to determine if the controller has been running long enough to start ATO functionality
ReefAngel.PHMin=305;
ReefAngel.PHMax=995;
for (int a=0;a<SIZE(menu_items);a++)
ReefAngel.InitMenu(pgm_read_word(&(menu_items[a])),a);
ReefAngel.AddDateTimeMenu();
ReefAngel.FeedingModePorts = Port5Bit |Port6Bit;
ReefAngel.WaterChangePorts = Port5Bit | Port6Bit;
ReefAngel.AddCustomColors();
InternalMemory.OverheatTemp_write( 790 );
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO(2, 120);
ReefAngel.StandardLights( Port1,11,25,17,15 );
ReefAngel.StandardLights( Port3,17,0,11,30 );
ReefAngel.WavemakerRandom1( Port5,15,45 );
ReefAngel.WavemakerRandom2( Port6,30,90 );
ReefAngel.StandardLights( Port7,13,0,15,30 );
if(ReefAngel.isWaterChangeMode()==1) Serial.println("In water change mode");
if(ReefAngel.isFeedingMode()==1) Serial.println("In feeding mode");
ReefAngel.LCD.BacklightOn();
ReefAngel.PWM.SetActinic( PWMSlope(11,30,17,0,11,50,60,0) );
DaylightPWMValue=PWMSlope(12,30,16,0,11,12,60,0);
CheckCloud();
ReefAngel.Portal( "CASPAR" );
int x,y;
void CheckCloud()
#define Clouds_Every_X_Days 1
#define Min_Cloud_Duration 7
#define Max_Cloud_Duration 15
#define Min_Clouds_per_Day 1
#define Max_Clouds_per_Day 3
// Which could mean 250 minutes of clouds. We need to make sure the PWMSlope can accomodate 250 minutes of effects or unforseen resul
// could happen.
// In our example, we have 510 minutes between Start_Cloud_After and End_Cloud_Before, so double the 250 minutes (or 500 minutes) can
// fit in that 510 minutes window.
static byte cloudchance=255;
static byte cloudduration=0;
static int cloudstart=0;
static byte numclouds=0;
static byte cloudindex=0;
static int LastNumMins=0;
#ifdef forcecloudcalculation
if (cloudchance==255)
#else
#endif
cloudchance=random(100);
// If we have cloud today
if (cloudchance)
lightningchance=random(100);
if (ForceCloud)
ForceCloud=false;
cloudchance=1;
cloudduration=10;
lightningchance=1;
cloudstart=NumMins(hour(),minute())+1;
if (cloudchance)
//is it time for cloud yet?
DaylightPWMValue=ReversePWMSlope(cloudstart,cloudstart+cloudduration,DaylightPWMValue,12,60);
ReefAngel.Relay.Off( Port8 );
if (lightningchance && (NumMins(hour(),minute())==(cloudstart+(cloudduration/2))) && second()<50)
else lightningstatus=0;
if (lightningstatus)
DaylightPWMValue=85;
DaylightPWMValue=0;
delay(1);
cloudindex++;
if (cloudindex < numclouds)
ReefAngel.LCD.DrawText(COLOR_NAVY,255,4,16,"CL");
ReefAngel.LCD.DrawText(0,255,20,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_NAVY,255,75,16,"Li");
ReefAngel.LCD.DrawText(0,255,95,16,"00:00");
ReefAngel.LCD.DrawText(COLOR_NAVY,255,44,30,"Duration");
int x=0;
if ((cloudstart/60)>=10) x=20;
else x=26;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart/60));
if ((cloudstart%60)>=10) x=38;
else x=44;
ReefAngel.LCD.DrawText(COLOR_RED,255,x,16,(cloudstart%60));
ReefAngel.LCD.DrawText(COLOR_GREEN,255,62,40,cloudduration);
if (lightningchance)
int x=0;
if (((cloudstart+(cloudduration/2))/60)>=10) x=95;
else x=101;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))/60));
if (((cloudstart+(cloudduration/2))%60)>=10) x=113;
else x=119;
ReefAngel.LCD.DrawText(COLOR_PURPLE,255,x,16,((cloudstart+(cloudduration/2))%60));
cstart*=60;
cend*=60;
if (n>cend) return PWMStart;
brennyn21
Re: CODE WITH TEMP PROBE PROBLEMS
Post by brennyn21 »
So it sounds like you have a bad temp probe. The temp ports are not oriented based on their position in the controller. Each temp probe has an id burnt into the chip which is how its orientation is set. So the lowest ID probe is always T1 then next lowest ID T2 then next lowest is T3 regardless of their position. As for why you have the green background is because you have
92 for the background color value instead of 255 which is white after the COLOR_BLACK
Your code is
[code]ReefAngel.LCD.DrawText(COLOR_RED,255,92,63,"ROOM");
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 92, 72, text, Num8x16);
[/code]
Correct code should be this below
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, 255, 89, 72, text, Num8x16);
Sincerely, Brennyn
brennyn21
Post by brennyn21 »
You can also replace the 255 with a Defined color like this below
ReefAngel.LCD.DrawLargeText(COLOR_BLACK, COLOR_WHITE, 89, 72, text, Num8x16);
So it goes (Text_Color, Background_Color, X_Position, Y_Poxition, text, font)
Sincerely, Brennyn
CASPAR
Post by CASPAR »
THAT FIXED THE GREEN BACK GROUND, BUT I DONT THINK I HAVE A BAD PROBE. I CAN LOAD ANOTHER CODE THAT USES ALL 3 PROBES AND IT DOESNT HAPPEN, ITS JUST THIS PARTICULAR CODE THAT IT DOES IT WITH.
