Anyway, here is what it looks like when you order it.... and here is my first demo screen hooked up to my RA... I'll be playing with some buttons and stuff soon.
-Jon
#include <ezLCD.h>
#include <SoftwareSerial.h>
EzLCD3_SW lcd( 10, 11 );
volatile boolean ezLCDInt = false; // flag to indicate interrupt
//screen set-up
#define NumScreens 4
int ScreenID=0;
//define for data over I2C
int maintemp=800;
int roomtemp=780;
int sumptemp=780;
int ph=700;
int moonlight=0;
byte TempRelay =15;
byte TempRelay2=15;
int wavetime=0;
int wavetime2=0;
int flow0=0;
int flow1=0;
int flow2=0;
int wmaker2;
byte mhour;
byte mminute;
byte msecond;
byte mday;
byte mmonth;
int myear = 2012;
byte Overflow;
byte Reservoir;
byte LATO;
byte HATO;
byte level;
byte atos;
//defines for sending relay data
byte lcdtype =0;
byte lcdrelay =0;
byte TouchOut[3];
//defines for button selection
int rate =0;
int selected = 0;
int prevSelected = 0;
int backcheck = 5;
Wire.begin(7);
Wire.onRequest(requestEvent);
Wire.onReceive(receiveEvent);
setTime(19,59,0,6,3,12);
lcd.begin( EZM_BAUD_RATE );
lcd.cls(BLACK);
// delay(1000);
//lcd.theme( id, embossDkColor, embossLtColor, textColor0, textColor1, textColorDisabled,
//color0, color1, colorDisabled, commonBkColor, fontw )
lcd.theme( 1, 9, 3, 0, 0, 0, 8, 9, 8, 1, 1 );
lcd.theme( 2, 5, 20, 3, 3, 3, 4, 5, 4, 2, 1 );
lcd.theme( 3, 13, 20, 3, 3, 3, 12, 13, 12, 2, 1 );
lcd.theme( 4, 7, 20, 0, 0, 0, 6, 7, 6, 2, 1 );
attachInterrupt(0, ezLCDevent, LOW);
//start up opttion screen
lcd.cls( 0 );
delay(1000);
lcd.fontw( 1, "sans24" );
lcd.string( 51, "STATUS" ); // stringId 1
lcd.string( 52, "RELAY1"); // stringId 2
lcd.string( 53, "RELAY2"); // stringId 2
lcd.button( 51, 10, 40, 100, 100, 1, 0,0, 1, 51 );
lcd.button( 52, 110, 40, 100, 100, 1, 0,0, 1, 52 );
lcd.button( 53, 210, 40, 100, 100, 1, 0,0, 1, 53 );
delay(1000);
if( ezLCDInt )
ezLCDInt = false;
if( lcd.isPressed(51) ) // if Button 1 is pressed:
ScreenID = 1;
if( lcd.isPressed(52) ) // if Button 2 was pressed:
ScreenID = 2;
if( lcd.isPressed(53) ) // if Button 2 was pressed:
ScreenID = 3;
if (ScreenID<0) ScreenID=NumScreens;
if (ScreenID>=NumScreens) ScreenID=0;
lcd.waitTouch();
switch (ScreenID)
case 1:
lcd.cls(BLACK);
delay(1000);
do
lcd.string( 54, "BACK" ); // stringId 1
lcd.button( 54, 200, 1, 50, 50, 1, 0, 0, 4, 54 );
delay (1000);
if( ezLCDInt )
ezLCDInt = false;
if( lcd.isPressed(54) ) // if Button 1 is pressed:
backcheck= 54;
lcd.color(WHITE);
DrawText(6,10,5,"Main Temp");
DrawSingleMonitor(3,maintemp,150,5,10);
delay(100);
DrawText(8,10,30,"Room Temp");
DrawSingleMonitor(3,roomtemp,150,30,10);
delay(100);
DrawText(10,10,55,"Sump Temp");
DrawSingleMonitor(3,sumptemp,150,55,10);
delay(100);
DrawText(12,10,80,"pH");
DrawSingleMonitor(3,ph,150,80,100);
delay(100);
DrawText(14,10,105,"Overflow");
DrawSingleMonitor(3,flow0,150,105,1);
delay(100);
DrawText(16,10,130,"Skimmer");
DrawSingleMonitor(3,flow1,150,130,1);
delay(100);
DrawText(7,10,155,"Phosban");
DrawSingleMonitor(4,flow2,150,155,1);
delay(100);
DrawSingleMonitor(4,backcheck,150,180,1);
delay(100);
lcd.image("logo200.gif",220,80);
DrawDate(4,6,205);
delay(100);
} while (backcheck != 54);
backcheck = 0;
ScreenID=0;
break;
case 2:
lcd.cls(0);
delay(1000);
do
// delay (100);
DrawText(3,1,1,"Relay #1");
DrawSwitch(5,40,1,2,3);
DrawSwitch(5,90,4,5,6);
DrawSwitch(5,140,7,8,9);
DrawSwitch(5,190,10,11,12);
DrawSwitch(160,40,13,14,15);
DrawSwitch(160,90,16,17,18);
DrawSwitch(160,140,19,20,21);
DrawSwitch(160,190,22,23,24);
lcd.string( 25, "BACK" ); // stringId 1
lcd.button( 25, 200, 1, 50, 40, 1, 0, 0, 4, 25 );
for(int i=1; i <= 25; i++)
boolean checked = lcd.isPressed(i);
if(checked) // if Button 1 is checked
selected = i; // store the selected widget
if(selected != prevSelected)
prevSelected = selected;
if (selected < 4)
lcdrelay=1;
if (selected == 1) lcdtype = 0;
else if (selected == 2) lcdtype = 1;
else if (selected == 3) lcdtype = 2;
else if (selected >3 && selected < 7)
lcdrelay=2;
if (selected == 4) lcdtype = 0;
else if (selected == 5) lcdtype = 1;
else if (selected == 6) lcdtype = 2;
else if (selected >6 && selected < 10)
lcdrelay=3;
if (selected == 7) lcdtype = 0;
else if (selected == 8) lcdtype = 1;
else if (selected == 9) lcdtype = 2;
else if (selected >9 && selected < 13)
lcdrelay=4;
if (selected == 10) lcdtype = 0;
else if (selected == 11) lcdtype = 1;
else if (selected == 12) lcdtype = 2;
else if (selected >12 && selected < 16)
lcdrelay=5;
if (selected == 13) lcdtype = 0;
else if (selected == 14) lcdtype = 1;
else if (selected == 15) lcdtype = 2;
else if (selected >15 && selected < 19)
lcdrelay=6;
if (selected == 16) lcdtype = 0;
else if (selected == 17) lcdtype = 1;
else if (selected == 18) lcdtype = 2;
else if (selected >18 && selected < 22)
lcdrelay=7;
if (selected == 19) lcdtype = 0;
else if (selected == 20) lcdtype = 1;
else if (selected == 21) lcdtype = 2;
else if (selected >21 && selected < 25)
lcdrelay=8;
if (selected == 22) lcdtype = 0;
else if (selected == 23) lcdtype = 1;
else if (selected == 24) lcdtype = 2;
TouchOut[1]=lcdtype;
TouchOut[2]=lcdrelay;
} while (selected != 25);
ScreenID=0;
selected=0;
break;
case 3:
lcd.cls(0);
delay(1000);
do
// delay (100);
DrawText(3,1,1,"Relay #2");
DrawSwitch(5,40,26,27,28);
DrawSwitch(5,90,29,30,31);
DrawSwitch(5,140,32,33,34);
DrawSwitch(5,190,35,36,37);
DrawSwitch(160,40,38,39,40);
DrawSwitch(160,90,41,42,43);
DrawSwitch(160,140,44,45,46);
DrawSwitch(160,190,47,48,49);
lcd.string( 50, "BACK" ); // stringId 1
lcd.button( 50, 200, 1, 50, 40, 1, 0, 0, 4, 50 );
for(int i=26; i <= 50; i++)
if (selected >25 && selected < 29)
lcdrelay=9;
if (selected == 26) lcdtype = 0;
else if (selected == 27) lcdtype = 1;
else if (selected == 28) lcdtype = 2;
else if (selected >28 && selected < 32)
lcdrelay=10;
if (selected == 29) lcdtype = 0;
else if (selected ==30) lcdtype = 1;
else if (selected == 31) lcdtype = 2;
else if (selected >31 && selected < 35)
lcdrelay=11;
if (selected == 32) lcdtype = 0;
else if (selected == 33) lcdtype = 1;
else if (selected == 34) lcdtype = 2;
else if (selected >34 && selected < 38)
lcdrelay=12;
if (selected == 35) lcdtype = 0;
else if (selected == 36) lcdtype = 1;
else if (selected == 37) lcdtype = 2;
else if (selected >37 && selected < 41)
lcdrelay=13;
if (selected == 38) lcdtype = 0;
else if (selected == 39) lcdtype = 1;
else if (selected == 40) lcdtype = 2;
else if (selected >40 && selected < 44)
lcdrelay=14;
if (selected == 41) lcdtype = 0;
else if (selected == 42) lcdtype = 1;
else if (selected == 43) lcdtype = 2;
else if (selected >43 && selected < 47)
lcdrelay=15;
if (selected == 44) lcdtype = 0;
else if (selected == 45) lcdtype = 1;
else if (selected == 46) lcdtype = 2;
else if (selected >46 && selected < 50)
lcdrelay=16;
if (selected == 47) lcdtype = 0;
else if (selected == 48) lcdtype = 1;
else if (selected == 49) lcdtype = 2;
} while (selected != 50);
ScreenID=0;
selected=0;
break;
void receiveEvent(int howMany)
if (howMany==5) // Our custom protocol is 13 bytes
byte cmd1,cmd2,cmd3,cmd4,cmd5;
cmd1=Wire.read();
cmd2=Wire.read();
cmd3=Wire.read();
cmd4=Wire.read();
cmd5=Wire.read();
if (cmd1=='$' && cmd2=='$' && cmd3=='$') // the first 3 bytes of the custom protocol are $$$ to ensure it's coming from RA
maintemp=(cmd4<<8)+cmd5;
void requestEvent() {
Wire.write(TouchOut, sizeof(TouchOut));
void ConvertNumToString(char* string, int num, byte decimal)
char temptxt[3];
int Temp = num;
if (Temp==0xFFFF) Temp=0;
itoa(Temp/decimal,string,10);
if (decimal>1)
itoa(Temp%decimal,temptxt,10);
strcat(string , ".");
if (Temp%decimal<10 && decimal==100) strcat(string , "0");
strcat(string , temptxt);
void DrawSingleMonitor(byte c,int Temp, byte x, byte y, byte decimal)
lcd.xy(x,y);
char text[7];
if ( Temp == 0xFFFF ) Temp = 0;
if (( Temp == 0 ) && ( decimal > 1 ))
strcpy(text, "Error");
ConvertNumToString(text, Temp, decimal);
lcd.color(BLACK);
lcd.rect(x,y,50,20);
lcd.fill(TRUE);
lcd.string(1,text);
lcd.color(c);
lcd.printStringId(1,10);
void DrawText(byte c, byte x, byte y, char* string)
lcd.color(c);
lcd.xy(x,y);
lcd.string(9,string);
lcd.printStringId(9,10);
void DrawSwitch(byte x, byte y, byte a, byte b, byte c)
lcd.color(WHITE);
lcd.theme( 2, 5, 20, 3, 3, 3, 4, 4, 4, 2, 1 );
lcd.theme( 3, 5, 20, 3, 3, 3, 13, 13, 13, 2, 1 );
delay(500);
lcd.string( 1, "OFF" ); // stringId 1
lcd.string( 2, "ON" ); // stringId 2
lcd.string( 3, "AUTO" ); // stringId 1
lcd.button( a, x, y, 50, 50, 1, 0, 0, 1, 1 );
lcd.button( b, x+50, y, 50, 50, 1, 0, 0, 2, 2 );
lcd.button( c, x+100, y, 50, 50, 1, 0, 0, 3, 3 );
void DrawDate(byte c, byte x, byte y)
//byte iTimeHourOffset=0;
char text[21];
char temp[]=" ";
strcpy(text,"");
itoa(month(),temp,10);
if (temp[1]==0) strcat(text,"0");
strcat(text,temp);
strcat(text,"/");
itoa(day(),temp,10);
strcat(text,temp);
strcat(text,"/");
itoa(year()-2000,temp,10);
strcat(text,temp);
strcat(text," ");
//if (iTimeHour>12) iTimeHourOffset=12;
itoa(hourFormat12(),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(minute(),temp,10);
strcat(text,temp);
strcat(text,":");
itoa(second(),temp,10);
strcat(text,temp);
if (isAM())
strcat(text," AM");
strcat(text," PM");
lcd.color(BLACK);
lcd.rect(x,y,200,20);
lcd.fill(TRUE);
lcd.string(1,text);
lcd.color(c);
void ezLCDevent( void ) {
ezLCDInt = true;
byte lcdrelay = 0;
byte lcdtype = 0;
//wire.write variable number
byte param[2];
byte TouchIn[4];
ReefAngel.LCD.Clear(BtnActiveColor,5,0,127,11);
ReefAngel.LCD.DrawText(DefaultBGColor,BtnActiveColor,30,3,"My Reef Angel");
// ReefAngel.LCD.DrawDate(6, 122);
ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params,
ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params);
ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
ReefAngel.LCD.DrawOutletBox(12, 120, TempRelay);
ReefAngel.LCD.DrawGraph(5, 15);
GetRelay();
// ReefAngel.LCD.DrawSingleMonitor(lcdrelay, 0,20,122, 1);
// ReefAngel.LCD.DrawSingleMonitor(lcdtype, 0,80,122, 1);
if (lcdrelay < 9)
if (lcdtype==0) // Turn port off
bitClear(ReefAngel.Relay.RelayMaskOn,lcdrelay-1);
bitClear(ReefAngel.Relay.RelayMaskOff,lcdrelay-1);
else if (lcdtype==1) // Turn port on
bitSet(ReefAngel.Relay.RelayMaskOn,lcdrelay-1);
bitSet(ReefAngel.Relay.RelayMaskOff,lcdrelay-1);
else if (lcdtype==2) // Turn port Auto
else if (lcdrelay < 17)
bitClear(ReefAngel.Relay.RelayMaskOnE[0],lcdrelay-9);
bitClear(ReefAngel.Relay.RelayMaskOffE[0],lcdrelay-9);
bitSet(ReefAngel.Relay.RelayMaskOnE[0],lcdrelay-9);
bitSet(ReefAngel.Relay.RelayMaskOffE[0],lcdrelay-9);
//send data parameter package to the auxillary monitor
Wire.beginTransmission(7); // transmit to device #10
Wire.write('$'); // send the $$$
Wire.write('$');
Wire.write('$');
paramsend(ReefAngel.Params.Temp[T1_PROBE]);
Wire.endTransmission(); // stop transmitting
void GetRelay() //relay status sent from ezLCD
Wire.requestFrom(7,3);
if(Wire.available())
for (int a=0;a<4;a++)
TouchIn[a]=Wire.read();
lcdtype=TouchIn[1];
lcdrelay=TouchIn[2];
//function to backage int into bytes for parameters temp, pH, timers, actinic%)
void paramsend(int a)
param[0]=(byte)(a>>8);
param[1]=(byte)(a);
Wire.write(param,2);
