New Head Unit....
jsclownfish
Re: New Head Unit....
Post by jsclownfish »
So, a quick update on the ezLCD... I haven't had a lot of time to play with it, but I think it can work depending on what you want to do. I am by no means a programmer, so I'm sure someone more adept could make it do lots of things. :geek: I've just worked on having it display data from the main and it seems to be working. I haven't had really tried to make the touchscreen communicate back. I've found the prepared widgets (buttons, sliders, etc) are a bit wonky to work with. :?
Anyway, here is what it looks like when you order it....
and here is my first demo screen hooked up to my RA...
I'll be playing with some buttons and stuff soon.
-Jon
very cool pictures. Looking good.
How are you attaching that to the head unit? As an expansion through USB? or TTL?
jsclownfish
I use an I2C connection with the USB. I have a USB cable with the lines split out on one end. I then connect it to the Arduino board on the ArLCD. The I2C needs a couple pull up resistors so I have it on a small breadboard for testing.
-Jon
00Warpig00
Post by 00Warpig00 »
I know I have been eyeballing this Touchscreen LCD
http://www.sainsmart.com/arduino-compat ... -2560.html
There is a sheild to fit it directly to a Arduino Mega 2560 as well. I think The Display with the sheild can be found on ebay for about $30
It's been calling my name...
Nick
180G FOWLR
20GH QT#1
29G QT#2
Just be careful with level shift....
That board does not have one.
I'm 99% confident that the LCD module is 3.3V.
I use similar screens and they are all 3.3V. If your Mega is 3.3V, then you are fine.
00Warpig00
Here is the same Display on ebay with the sheild and even a Sainsmart clone of an Arduino 2560 Mega all for about $50
I came so very very close to purchasing this package.
http://www.ebay.com/itm/SainSmart-Mega2 ... 3f1a0ab450
I did buy one but with the more common blue 2 line LCD with the up/down/L/R/Enter buttons. Cant remember the LCD model number but it's a common one used in Arduino projects. Should arrive any day now.
Nick
180G FOWLR
20GH QT#1
29G QT#2
jsclownfish
I spent the good part of the weekend working on this "ezLCD" system to try and accomplish three things:
1) receiving info from the main to display on a bigger LCD
2) control the relays from the touch screen
3) alternate between screens to accomplish 1&2
Seems like it would be straigthforward from the system libraries and the "widgets", but I had a tough time getting them to work appropriately and had to litter the code with delay steps to allow things to display correctly. This causes things to show correctly, but they don't always load as you would expect and it requires you to hold buttons 2 or 3 seconds before you see the activity. I'm guessing this has to do with the speed the LCD communicates with the Arduino board. I also had to add back in code for text display, clock, etc that is already in the RA LCD library but not in this LCD. Nevertheless, I did eventually get it to work :geek: , but I wouldn't say it is robust. Here is a video link of how it looks....(nevermind the football in the background, I was multitasking ;) )
[youtube]http://www.youtube.com/watch?v=6O-KktgTzD8[/youtube]
If you're curious, here is what the code I put together looks like for the ezLCD. I'll admit I have no idea why some of the delays work, I just started adding them in places until it displayed correctly.
#include <ezLCD.h>
#include <SoftwareSerial.h>
EzLCD3_SW lcd( 10, 11 );
volatile boolean ezLCDInt = false; // flag to indicate interrupt
//screen set-up
#define NumScreens 4
int ScreenID=0;
//define for data over I2C
int maintemp=800;
int roomtemp=780;
int sumptemp=780;
int ph=700;
int moonlight=0;
byte TempRelay =15;
byte TempRelay2=15;
int wavetime=0;
int wavetime2=0;
int flow0=0;
int flow1=0;
int flow2=0;
int wmaker2;
byte mhour;
byte mminute;
byte msecond;
byte mday;
byte mmonth;
int myear = 2012;
byte Overflow;
byte Reservoir;
byte LATO;
byte HATO;
byte level;
byte atos;
//defines for sending relay data
byte lcdtype =0;
byte lcdrelay =0;
byte TouchOut[3];
//defines for button selection
int rate =0;
int selected = 0;
int prevSelected = 0;
int backcheck = 5;
  Wire.begin(7);
  Wire.onRequest(requestEvent);
  Wire.onReceive(receiveEvent);
  setTime(19,59,0,6,3,12);
  lcd.begin( EZM_BAUD_RATE );
  lcd.cls(BLACK);
//  delay(1000);
 //lcd.theme( id, embossDkColor, embossLtColor, textColor0, textColor1, textColorDisabled,
 //color0, color1, colorDisabled, commonBkColor, fontw )
  lcd.theme( 1, 9, 3, 0, 0, 0, 8, 9, 8, 1, 1 );
  lcd.theme( 2, 5, 20, 3, 3, 3, 4, 5, 4, 2, 1 );
  lcd.theme( 3, 13, 20, 3, 3, 3, 12, 13, 12, 2, 1 );
  lcd.theme( 4, 7, 20, 0, 0, 0, 6, 7, 6, 2, 1 );
 attachInterrupt(0, ezLCDevent, LOW);
 //start up opttion screen
  lcd.cls( 0 );
  delay(1000);
  lcd.fontw( 1, "sans24" );
  lcd.string( 51, "STATUS" ); // stringId 1
  lcd.string( 52, "RELAY1"); // stringId 2
  lcd.string( 53, "RELAY2"); // stringId 2
  lcd.button( 51, 10, 40, 100, 100, 1, 0,0, 1, 51 );
  lcd.button( 52, 110, 40, 100, 100,  1, 0,0, 1, 52 );
  lcd.button( 53, 210, 40, 100, 100,  1, 0,0, 1, 53 );
  delay(1000);
  if(  ezLCDInt )
    ezLCDInt = false;
  if( lcd.isPressed(51) ) // if Button 1 is pressed:
    ScreenID = 1;
  if( lcd.isPressed(52) ) // if Button 2 was pressed:
    ScreenID = 2;
  if( lcd.isPressed(53) ) // if Button 2 was pressed:
    ScreenID = 3;
  if (ScreenID<0) ScreenID=NumScreens;
  if (ScreenID>=NumScreens) ScreenID=0;
  lcd.waitTouch();
  switch (ScreenID)
  case 1:
  lcd.cls(BLACK);
  delay(1000);
  do
  lcd.string( 54, "BACK" ); // stringId 1
  lcd.button( 54, 200, 1, 50, 50, 1, 0, 0, 4, 54 );
  delay (1000);
  if(  ezLCDInt )
    ezLCDInt = false;
  if( lcd.isPressed(54) ) // if Button 1 is pressed:
    backcheck= 54;
  lcd.color(WHITE);
  DrawText(6,10,5,"Main Temp");
  DrawSingleMonitor(3,maintemp,150,5,10);
    delay(100);
  DrawText(8,10,30,"Room Temp");
  DrawSingleMonitor(3,roomtemp,150,30,10);
  delay(100);
  DrawText(10,10,55,"Sump Temp");
  DrawSingleMonitor(3,sumptemp,150,55,10);
    delay(100);
  DrawText(12,10,80,"pH");
  DrawSingleMonitor(3,ph,150,80,100);
    delay(100);
  DrawText(14,10,105,"Overflow");
  DrawSingleMonitor(3,flow0,150,105,1);
    delay(100);
  DrawText(16,10,130,"Skimmer");
  DrawSingleMonitor(3,flow1,150,130,1);
    delay(100);
  DrawText(7,10,155,"Phosban");
  DrawSingleMonitor(4,flow2,150,155,1);
    delay(100);
  DrawSingleMonitor(4,backcheck,150,180,1);
    delay(100);
  lcd.image("logo200.gif",220,80);
  DrawDate(4,6,205);
    delay(100);
     } while (backcheck != 54);
  backcheck = 0;
  ScreenID=0;
  break;
case 2:
     lcd.cls(0);
     delay(1000);
  do
 // delay (100);
     DrawText(3,1,1,"Relay #1");
     DrawSwitch(5,40,1,2,3);
     DrawSwitch(5,90,4,5,6);
     DrawSwitch(5,140,7,8,9);
     DrawSwitch(5,190,10,11,12);
     DrawSwitch(160,40,13,14,15);
     DrawSwitch(160,90,16,17,18);
     DrawSwitch(160,140,19,20,21);
     DrawSwitch(160,190,22,23,24);
     lcd.string( 25, "BACK" ); // stringId 1
     lcd.button( 25, 200, 1, 50, 40, 1, 0, 0, 4, 25 );
     for(int i=1; i <= 25; i++)
       boolean checked = lcd.isPressed(i);
       if(checked)   // if Button 1 is checked
        selected = i; // store the selected widget
     if(selected != prevSelected)
       prevSelected = selected;
     if (selected < 4)
     lcdrelay=1;
     if (selected == 1) lcdtype = 0;
     else if (selected == 2) lcdtype = 1;
     else if (selected == 3) lcdtype = 2;
     else if (selected >3 && selected < 7)
     lcdrelay=2;
     if (selected == 4) lcdtype = 0;
     else if (selected == 5) lcdtype = 1;
     else if (selected == 6) lcdtype = 2;
     else if (selected >6 && selected < 10)
     lcdrelay=3;
     if (selected == 7) lcdtype = 0;
     else if (selected == 8) lcdtype = 1;
     else if (selected == 9) lcdtype = 2;
     else if (selected >9 && selected < 13)
     lcdrelay=4;
     if (selected == 10) lcdtype = 0;
     else if (selected == 11) lcdtype = 1;
     else if (selected == 12) lcdtype = 2;
     else if (selected >12 && selected < 16)
     lcdrelay=5;
     if (selected == 13) lcdtype = 0;
     else if (selected == 14) lcdtype = 1;
     else if (selected == 15) lcdtype = 2;
     else if (selected >15 && selected < 19)
     lcdrelay=6;
     if (selected == 16) lcdtype = 0;
     else if (selected == 17) lcdtype = 1;
     else if (selected == 18) lcdtype = 2;
     else if (selected >18 && selected < 22)
     lcdrelay=7;
     if (selected == 19) lcdtype = 0;
     else if (selected == 20) lcdtype = 1;
     else if (selected == 21) lcdtype = 2;
     else if (selected >21 && selected < 25)
     lcdrelay=8;
     if (selected == 22) lcdtype = 0;
     else if (selected == 23) lcdtype = 1;
     else if (selected == 24) lcdtype = 2;
     TouchOut[1]=lcdtype;
     TouchOut[2]=lcdrelay;
     } while (selected != 25);
  ScreenID=0;
  selected=0;
  break;
case 3:
     lcd.cls(0);
     delay(1000);
  do
 // delay (100);
     DrawText(3,1,1,"Relay #2");
     DrawSwitch(5,40,26,27,28);
     DrawSwitch(5,90,29,30,31);
     DrawSwitch(5,140,32,33,34);
     DrawSwitch(5,190,35,36,37);
     DrawSwitch(160,40,38,39,40);
     DrawSwitch(160,90,41,42,43);
     DrawSwitch(160,140,44,45,46);
     DrawSwitch(160,190,47,48,49);
     lcd.string( 50, "BACK" ); // stringId 1
     lcd.button( 50, 200, 1, 50, 40, 1, 0, 0, 4, 50 );
     for(int i=26; i <= 50; i++)
     if (selected >25 && selected < 29)
     lcdrelay=9;
     if (selected == 26) lcdtype = 0;
     else if (selected == 27) lcdtype = 1;
     else if (selected == 28) lcdtype = 2;
     else if (selected >28 && selected < 32)
     lcdrelay=10;
     if (selected == 29) lcdtype = 0;
     else if (selected ==30) lcdtype = 1;
     else if (selected == 31) lcdtype = 2;
     else if (selected >31 && selected < 35)
     lcdrelay=11;
     if (selected == 32) lcdtype = 0;
     else if (selected == 33) lcdtype = 1;
     else if (selected == 34) lcdtype = 2;
     else if (selected >34 && selected < 38)
     lcdrelay=12;
     if (selected == 35) lcdtype = 0;
     else if (selected == 36) lcdtype = 1;
     else if (selected == 37) lcdtype = 2;
     else if (selected >37 && selected < 41)
     lcdrelay=13;
     if (selected == 38) lcdtype = 0;
     else if (selected == 39) lcdtype = 1;
     else if (selected == 40) lcdtype = 2;
     else if (selected >40 && selected < 44)
     lcdrelay=14;
     if (selected == 41) lcdtype = 0;
     else if (selected == 42) lcdtype = 1;
     else if (selected == 43) lcdtype = 2;
     else if (selected >43 && selected < 47)
     lcdrelay=15;
     if (selected == 44) lcdtype = 0;
     else if (selected == 45) lcdtype = 1;
     else if (selected == 46) lcdtype = 2;
     else if (selected >46 && selected < 50)
     lcdrelay=16;
     if (selected == 47) lcdtype = 0;
     else if (selected == 48) lcdtype = 1;
     else if (selected == 49) lcdtype = 2;
     } while (selected != 50);
  ScreenID=0;
  selected=0;
  break;
void receiveEvent(int howMany)
    if (howMany==5)  // Our custom protocol is 13 bytes
    byte cmd1,cmd2,cmd3,cmd4,cmd5;
      cmd1=Wire.read();
      cmd2=Wire.read();
      cmd3=Wire.read();
      cmd4=Wire.read();
      cmd5=Wire.read();
    if (cmd1=='$' && cmd2=='$' && cmd3=='$') // the first 3 bytes of the custom protocol are $$$ to ensure it's coming from RA
      maintemp=(cmd4<<8)+cmd5;
void requestEvent() {
    Wire.write(TouchOut, sizeof(TouchOut));
void ConvertNumToString(char* string, int num, byte decimal)
    char temptxt[3];
    int Temp = num;
    if (Temp==0xFFFF) Temp=0;
	itoa(Temp/decimal,string,10);
	if (decimal>1)
		itoa(Temp%decimal,temptxt,10);
		strcat(string , ".");
		if (Temp%decimal<10 && decimal==100) strcat(string , "0");
		strcat(string , temptxt);
void DrawSingleMonitor(byte c,int Temp, byte x, byte y, byte decimal)
        lcd.xy(x,y);
        char text[7];
	if ( Temp == 0xFFFF ) Temp = 0;
	if (( Temp == 0 ) && ( decimal > 1 ))
	strcpy(text, "Error");
	ConvertNumToString(text, Temp, decimal);
        lcd.color(BLACK);
        lcd.rect(x,y,50,20);
        lcd.fill(TRUE);
        lcd.string(1,text);
        lcd.color(c);
        lcd.printStringId(1,10);
void DrawText(byte c, byte x, byte y, char* string)
	lcd.color(c);
        lcd.xy(x,y);
        lcd.string(9,string);
        lcd.printStringId(9,10);
void DrawSwitch(byte x, byte y, byte a, byte b, byte c)
  lcd.color(WHITE);
  lcd.theme( 2, 5, 20, 3, 3, 3, 4, 4, 4, 2, 1 );
  lcd.theme( 3, 5, 20, 3, 3, 3, 13, 13, 13, 2, 1 );
  delay(500);
  lcd.string( 1, "OFF" ); // stringId 1
  lcd.string( 2, "ON" ); // stringId 2
  lcd.string( 3, "AUTO" ); // stringId 1
  lcd.button( a, x, y, 50, 50, 1, 0, 0, 1, 1 );
  lcd.button( b, x+50, y, 50, 50, 1, 0, 0, 2, 2 );
  lcd.button( c, x+100, y, 50, 50, 1, 0, 0, 3, 3 );
void DrawDate(byte c, byte x, byte y)
    //byte iTimeHourOffset=0;
    char text[21];
    char temp[]="  ";
    strcpy(text,"");
    itoa(month(),temp,10);
    if (temp[1]==0) strcat(text,"0");
    strcat(text,temp);
    strcat(text,"/");
    itoa(day(),temp,10);
    strcat(text,temp);
    strcat(text,"/");
    itoa(year()-2000,temp,10);
    strcat(text,temp);
    strcat(text," ");
    //if (iTimeHour>12) iTimeHourOffset=12;
    itoa(hourFormat12(),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(minute(),temp,10);
    strcat(text,temp);
    strcat(text,":");
    itoa(second(),temp,10);
    strcat(text,temp);
    if (isAM())
        strcat(text," AM");
        strcat(text," PM");
    lcd.color(BLACK);
    lcd.rect(x,y,200,20);
    lcd.fill(TRUE);
    lcd.string(1,text);
    lcd.color(c);
void ezLCDevent( void ) {
  ezLCDInt = true;
and the demo code on the RA unit I used to test it. I ony had the main temp probe connected to see that it updated correctly.
byte lcdrelay = 0;
byte lcdtype = 0;
//wire.write variable number
byte param[2];
byte TouchIn[4];
  ReefAngel.LCD.Clear(BtnActiveColor,5,0,127,11);
  ReefAngel.LCD.DrawText(DefaultBGColor,BtnActiveColor,30,3,"My Reef Angel");
//  ReefAngel.LCD.DrawDate(6, 122);
  ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params,
  ReefAngel.LCD.DrawMonitor(15, 70, ReefAngel.Params);
  ReefAngel.LCD.DrawOutletBox(12, 103, TempRelay);
  ReefAngel.LCD.DrawOutletBox(12, 120, TempRelay);
  ReefAngel.LCD.DrawGraph(5, 15);
GetRelay();
//  ReefAngel.LCD.DrawSingleMonitor(lcdrelay, 0,20,122, 1);
//  ReefAngel.LCD.DrawSingleMonitor(lcdtype, 0,80,122, 1);
 if (lcdrelay < 9)
  if (lcdtype==0)  // Turn port off
    bitClear(ReefAngel.Relay.RelayMaskOn,lcdrelay-1);
    bitClear(ReefAngel.Relay.RelayMaskOff,lcdrelay-1);
   else if (lcdtype==1)  // Turn port on
    bitSet(ReefAngel.Relay.RelayMaskOn,lcdrelay-1);
    bitSet(ReefAngel.Relay.RelayMaskOff,lcdrelay-1);
    else if (lcdtype==2)  // Turn port Auto
else if (lcdrelay < 17)
    bitClear(ReefAngel.Relay.RelayMaskOnE[0],lcdrelay-9);
    bitClear(ReefAngel.Relay.RelayMaskOffE[0],lcdrelay-9);
    bitSet(ReefAngel.Relay.RelayMaskOnE[0],lcdrelay-9);
    bitSet(ReefAngel.Relay.RelayMaskOffE[0],lcdrelay-9);
//send data parameter package to the auxillary monitor
         Wire.beginTransmission(7);      // transmit to device #10
         Wire.write('$');         // send the $$$
         Wire.write('$');
         Wire.write('$');
         paramsend(ReefAngel.Params.Temp[T1_PROBE]);
         Wire.endTransmission();      // stop transmitting
void GetRelay()  //relay status sent from ezLCD
  Wire.requestFrom(7,3);
  if(Wire.available())
    for (int a=0;a<4;a++)
      TouchIn[a]=Wire.read();
  lcdtype=TouchIn[1];
  lcdrelay=TouchIn[2];
//function to backage int into bytes for parameters temp, pH, timers, actinic%)
void paramsend(int a)
  param[0]=(byte)(a>>8);
  param[1]=(byte)(a);
  Wire.write(param,2);
-jon
Cool :)
that is pretty sweet.
Smotz
Post by Smotz »
Nice where can I buy the completed product? :D
jsclownfish
I need to get back to it. :geek: I kinda put in on the back burner as Roberto was moving forward on an LCD extension.
Jon
mikedizon
Post by mikedizon »
Hey thats cool. This serves as an inspiration for the next Generation Ra controllers.
The only problem here is if your hands get wet or dirty and you accidentally touch it. I wonder if this touch LCD screen is like the apple ipad screens really heavy duty.
89delta
Post by 89delta »
I'm looking into doing a touch screen as well. Right now I'm getting all the required pieces needed to prototype a stackable shield for the mega2560. Thought about using a 3.2" tft I got a 7" tft as well. I figured there would be more room on the 7" to display a lot of parameters, but would still try the 3.2" tft to display these other parameters on different screens. Setup menu would be basic time, pH calibration, feed, water change modes as well as clearing any flags. Will take a bit with working 12hr days.
mikedizon
Post by mikedizon »
Excited for a new touch screen for my RA controller.
The joystick has been ok but I can already retire them. Now
that 1 of my RA controller joystick stop working properly.
I cannot scroll anymore to the right. Despite the repair.
Im just waiting for the new Touch Screen LCD controller
to be available.
This is my guess eventually in time the other RA joystick will
break down and you will want to have the new LCD touch screen
ready if not as a back up with you.
The important thing is the LCD screen should be robust.
specially near seawater.
Anyone know when the RA LCD touch screen will be ready.
Ismaclst
Post by Ismaclst »
I could be wrong but I don't think it's going to happen. Few people have used tablets instead, considering they are so cheap now.
http://forum.reefangel.com/viewtopic.php?f=2&t=3118
I believe there are prototype touch screens in the wild, but given the cost a cheap, dedicated 7" Android tablet running the RA app is a more reasonable way to go. I've done this for a few years now and it works great.
troylong45
Post by troylong45 »
Robert I seen u said you can run a secondary screen with Adriano shield or something like that. I would like to have a larger screen but don't want it to run from wifi cud of the update Intervals . And would like live feed on it and direct interface on my phone sometimes on the app it will lag or error sometimes and then I gotta do it again.
A cheap tablet or custom LCD touch screen would be cool but have no idea what route to take and if some help form from someone to set up a secondary larger touch screen would be great
troylong45
A cheap android tablet running the ReefAngel UApp or Binder's app.. doesn't have to rely on the cloud..
troylong45
It don't work properly for me same on uapp (home ipxxxxxxxx:2000/wifi) and the Android app on home . It's to delayed and errors sometimes while its loading. So i think hard wired is the way I have to go.
Thats not uapp. Try downloading the native version of the uapp, not the /wifi, that one is buggy.
troylong45
Where do i find that
Not sure i don't use android :P
troylong45
Thanks Lee and cosmith71, I got it to download it doenst seem to be a live feed only if u hit refresh . The fuction is there but not the constant up to date feed. So that won't really wrok for me I'll probably have to search some more on if anyone has done a Tutorial on a touch screen and or bigger screen.
Roberto, can we add auto refresh in the uapp?
Yeah, but the cloud server would take care of this and provide a live stream of data without the need of refresh.
You will just have to wait a little more for the cloud server to be a reality :)
troylong45
Ok thanks guys till then Ill research on a new controller screw till then
